Default "Wire Blend" Example buggy?
schiho
i had issues with the "wire blend" sop as the blend operation did weired movement like rotation by 180° before coming to the end-position.
I have attached a file
Do you have the same problems?
Even the example "wire blend" is stretching at the end of the animation the wire unnaturally.
thanks!
wireBroken.hipnc
