harima Posted January 30, 2014 Share Posted January 30, 2014 Hi All I have a simple DNA helix that I want to unfold at specific points ( imagine that as the transcription of DNA starts happening the two parts of the helix start facing each other straight.) So my idea for now is to use two copies of my setup. One in a helix position and one with two straight lines facing each other. The blend shapes interpolates nicely but I cant figure out how to make it work wherever I choose. I guess there is a way to control the region with a metaball or a bounding box but cant figure it out. See file attached Thank you all dna.hipnc Quote Link to comment Share on other sites More sharing options...
Milan Posted January 30, 2014 Share Posted January 30, 2014 The most straightforward way I can think of is using a vopsop to blend them. Plug both inputs into it, import P from second input and blend between P and the imported P based on any attribute using mix node for example. I've just used remapped position Y as bias for illustration. dna_fix.hipnc Quote Link to comment Share on other sites More sharing options...
harima Posted January 30, 2014 Author Share Posted January 30, 2014 Thanks for the tip Milan! Cheers Quote Link to comment Share on other sites More sharing options...
