Multiple Expressions on blast node?
schiho
i would like to add a second condition to my blast node, how this is done in Houdini?
if(pscale > 0.5 && $F > 30)
thats what i want to achieve. @pscale > 0.4 but what about the second condition? how is the syntax?
thanks
  On 2/4/2014 at 10:38 AM, schiho said:
thanks
This looks like a legal expression to me, you only forgot to put the output to the conditions, like:
if($PSCALE > 0.5 && $F > 30, 1, 0)
The trick is that I don't think you can't do this in a blast node, but a delete node which has the parameter field for expression.
Cheers
The Delete node is quite slow compared to the the Blast node. If you're dealing with a lot of points you might want to use an AttribVOP or AttribWrangle instead.
The VEXpression version is::
if(@pscale>0.5 && @Frame>30)
    removepoint(0,@ptnum);
