jvn Posted June 25, 2004 Share Posted June 25, 2004 Hi ok... i have this problem ive just done this animation and i want to see how the animation is with the audio... so i use the flip book and i want to start the flipbook from frame 400 - 820 and also include an audio file... but... that does not work... and i found out the if u start the flip book from frame 1 the audio file will be included properly so does anyone know a way so that i can start the flip book from any frame and have the audio start from that frame??? or some other easy way i can preview my animatoin with audio... thanks Quote Link to comment Share on other sites More sharing options...
malexander Posted June 26, 2004 Share Posted June 26, 2004 The audio is always aligned to frame 1 in the flipbook. This has been fixed in more recent versions, so that you can set the audio frame/offset directly in the Flipbook dialog. However, even without this version, you can still adjust the audio position using the 'Load Audio' dialog (File->Load Audio, or Alt+a). Set the it so that: Frame [ 400 ] is at [ 0] audio seconds If you have a more recent version, you can do this directly in the Flipbook dialog, which is nice because it will remember your settings. Quote Link to comment Share on other sites More sharing options...
jvn Posted June 28, 2004 Author Share Posted June 28, 2004 sweeet.... thanx Quote Link to comment Share on other sites More sharing options...
