glassman3d Posted February 19, 2014 Share Posted February 19, 2014 Hi there I am building a pc2 writer sop to export point cache data from Houdini I have a working python solution but it can be a bit slow (code has been hacked from the various examples on odforce ect) see below: import sys, struct def doCache(): sf = hou.evalParm("startframe") ef = hou.evalParm("endframe") sr = 1 ns = (ef - sf) + 1 geo = hou.pwd().geometry() points = geo.points() np = len(points) pc2File = open(hou.evalParm("file"), "wb") geo = hou.pwd().geometry() # Write header headerFormat='<12siiffi' headerStr = struct.pack(headerFormat, "POINTCACHE2\0", 1, np, sf, sr, ns) pc2File.write(headerStr) # iterate points def writePP(p,f): hou.setFrame(f) curp = p.position() curps = pc2File.write( struct.pack('<fff', float(curp[0]), float(-curp[2]), float(curp[1]) ) ) a = [ writePP(p,f) for f in xrange(sf, sf+ns, sr) for p in geo.points() ] # close file pc2File.flush() pc2File.close() Due to slow speeds I am attempting to implement this using inlinecpp to speed up the execution time. My attempt can be found below, (non-functional at the mo). I am a HDK newb so there are probably lots of very simple mistakes in there. Would anyone with HDK experience be able to give me a few pointers in where I am going wrong? import sys import struct import inlinecpp writePts = inlinecpp.createLibrary( name="cpp_string_library", includes="#include <GU/GU_Detail.h>, #include <FS/FS_Writer.h>, #include <UT/UT_Vector3.h>, #include <HOM/HOM_Module.h>", function_sources=[ """void writePC2(GU_Detail *gdp, const char *filename, const char *pc2, int *numPoints, float *start, float *samplerate, int *numSamples ) { // open the file for writing FS_Writer fs(filename); ostream *file = fs.getStream(); // write header file << pc2; file << int(1); file << numPoints; file << start; file << samplerate; file << numSamples; // iterate through frames through points for ( float i=start; i<end; ++i) { HOM_Module::setFrame( double(i) ) //iterate through the points GA_Offset ptoff; GA_FOR_ALL_PTOFF(gdp, ptoff) { UT_Vector3 pos = gdp->getPos3(ptoff); file << pos.x << pos.y << pos.z; } } // close the file file.close() } """]) def doCache(): sf = hou.evalParm("startframe") ef = hou.evalParm("endframe") sr = 1 ns = (ef - sf) + 1 geo = hou.pwd().geometry() filename = hou.evalParm("file") pc2 = "POINTCACHE2\0" writePts.writePC2(geo, filename, pc2, len(geo.points), sf, sr, ns) Much obliged!!! Sam Swift-Glasman Quote Link to comment Share on other sites More sharing options...
symek Posted February 19, 2014 Share Posted February 19, 2014 (edited) I know this is not what you're asking for, but I can hand you some code to shorten your pre-alembic pain. Written carelessly as a last resort for XSI->Houdini pipeline, was in use permanently few years. But at least I'm sure it works. btw it compiles on H13, but lots' of warnings remain as code is outdated. SOP_PointCache.zip Edited February 19, 2014 by symek Quote Link to comment Share on other sites More sharing options...
glassman3d Posted February 19, 2014 Author Share Posted February 19, 2014 (edited) Hi Symek thanks for that code! it'll come in very handy when I get to the reader, and I will go through it to see if there is anything I can use on the way out of Houdini as well! we were using alembic but the exocortex implementation in softimage is quite buggy as a point cache best Sam Edited February 19, 2014 by glassman3d Quote Link to comment Share on other sites More sharing options...
symek Posted February 19, 2014 Share Posted February 19, 2014 (edited) This is what I've heard about this plugin and wasn't even considering buying it. Alembic pipe from and to Maya is such a pleasure to work with after pc2... As to your code, I can't be sure since I rarely use inlinecpp, but meanwhile someone more educated watch this thread, I would say taht I hardly believe you can cook PythonSOP in different frame than current one. I'm actually not even sure you can cook any SOP like this. If you don't want to iterate over frames in Python, AFAIK you need to set context to different time, then force cook node, copy points and such. Something like (untested): other_frame_context = context; for ( float i=start; i<end; ++i) { float time = OPgetDirector()->getChannelManger()->getTime(i); other_frame_context.setTime(time); if(lockInput(0, other_frame_contex) >= UT_ERROR_ABORD) { unlockInput(0); return error(); } duplicatePointSource(other_frame_context); /// and the rest the same... //// //iterate through the points GA_Offset ptoff; GA_FOR_ALL_PTOFF(gdp, ptoff) { UT_Vector3 pos = gdp->getPos3(ptoff); file << pos.x << pos.y << pos.z; } unlockInput(0); } This is more or less how this could be done in ordinary SOP, but not sure about PythonSOP... Edited February 19, 2014 by symek Quote Link to comment Share on other sites More sharing options...
glassman3d Posted February 20, 2014 Author Share Posted February 20, 2014 (edited) Hi Symek Every package besides Softimage seems to have implemented Alembic in a robust and sensible fashion to my immense frustration, even renderers like Arnold support it natively! thanks again for the code, one more piece to the puzzle! I should have specified, this is only a sop in the sense that it lives in sops - more of a 'soprop' like the filecache node for example. My code lives in a callback on an export button, My intention was to to iterate through the timeline, cook each frame, and append the point positions to the binary file in python for example: # iterate points def writePP(p,f): hou.setFrame(f) curp = p.position() curps = pc2File.write( struct.pack('<fff', float(curp[0]), float(-curp[2]), float(curp[1]) ) ) a = [ writePP(p,f) for f in xrange(sf, sf+ns, sr) for p in geo.points() ] could I ask is it necessary to unlock/lock the Input as below if I am in a callback context? if(lockInput(0, other_frame_contex) >= UT_ERROR_ABORD) { unlockInput(0); return error(); } duplicatePointSource(other_frame_context); Could I avoid this by iterating the timeline in python and calling my hdk function only to iterate the points? thanks for all your help, I have really jumped in the deep end here! Edited February 20, 2014 by glassman3d Quote Link to comment Share on other sites More sharing options...
symek Posted February 20, 2014 Share Posted February 20, 2014 Afaik locking is necessary while cooking nodes in HDK. Iterating over frames in python seems to be the easiest approach, though little slower. Are you sure costs are worth efforts? You can get any attribute as binary string and save it quickly to file like (untested): header = struck.pack(....) file = open(..., "wb") file.write(header) for frame in frames: hou.setFrame(frame) geo = some_node.geometry() pos = geo.pointFloatAttribValuesAsString("P") file.write(pos) // for all points at once file.close() Quote Link to comment Share on other sites More sharing options...
glassman3d Posted February 26, 2014 Author Share Posted February 26, 2014 (edited) oh I wasn't aware of pointFloatAttribValuesAsString() - that could work very well I will give that a go now thanks! UPDATE: It worked like a charm - I can cache out 150 frames of point positions for 90,000 points in about 30 secs perfectly fine for my current needs - here is my code for perusal thanks symek! import sys import struct def doCache(): sf = hou.evalParm("startframe") ef = hou.evalParm("endframe") sr = 1 ns = (ef - sf) + 1 geo = hou.pwd().geometry() points = geo.points() np = len(points) pc2File = open(hou.evalParm("file"), "wb") with hou.InterruptableOperation("PC2 Cache",open_interrupt_dialog=True) as operation: with hou.InterruptableOperation("Exporting %s" % hou.pwd().name(),open_interrupt_dialog=True) as export: # Write header headerFormat='<12siiffi' #headerStr = struct.pack(headerFormat, 'P','O','I','N','T','C','A','C','H','E','2','\0', 1, np, sf, sr, ns) headerStr = struct.pack(headerFormat, "POINTCACHE2\0", 1, np, sf, sr, ns) pc2File.write(headerStr) for f in range(sf, sf+ns, sr): hou.setFrame(f) pos = geo.pointFloatAttribValuesAsString("P") pc2File.write(pos) export.updateProgress( f/ns ) operation.updateLongProgress(0.5 * (f/ns) ) with hou.InterruptableOperation("Finishing",open_interrupt_dialog=True) as finish: pc2File.flush() pc2File.close() finish.updateProgress(1) operation.updateLongProgress(1) Edited February 26, 2014 by glassman3d Quote Link to comment Share on other sites More sharing options...
glassman3d Posted February 26, 2014 Author Share Posted February 26, 2014 (edited) for completeness thought I would post the feedback I have received from SESI I will probably keep going with the hdk implementation as a learning exercise: You need to include <GA/GA_Types.h> to get GA_Offset. And you need to include <GA/GA_GBMacros.h> to get GA_FOR_ALL_PTOFF. You can implement hou.setFrame() in the HDK like so: #include <CH/CH_Manager.h> #include <OP/OP_Director.h> OPgetDirector()->setTime( OPgetDirector()->getChannelManager()->getTime(the_frame_to_be_set)); You can use the convenience function, UTwrite() to write out binary data to the file. For example: #include <FS/FS_Writer.h> #include <UT/UT_NTStreamUtil.h> int some_number = 3; FS_Writer writer("/path/to/file"); UTwrite(*writer.getStream(), some_number); Edited February 26, 2014 by glassman3d Quote Link to comment Share on other sites More sharing options...
glassman3d Posted February 26, 2014 Author Share Posted February 26, 2014 also on the reading side I managed to hack the pc2read otl to get faster performance using numpy import numpy # This code is called when instances of this SOP cook. geo = hou.pwd().geometry() # Read from Point Cache if hou.parm("read").eval(): pc2File = open(hou.evalParm("file"), "rb") # Header headerFormat='<12siiffi' pc2Header = pc2File.read(struct.calcsize(headerFormat)) fields = struct.unpack(headerFormat, pc2Header) signature, fileVer, numPoints, startFrame, sampleRate, numSamples = fields hou.parm("signature").set(signature) hou.parm("fileversion").set(str(fileVer)) hou.parm("points").set(str(numPoints)) hou.parm("samples").set(str(numSamples)) hou.parm("startframe").set(str(startFrame)) hou.parm("samplerate").set(str(sampleRate)) hou.parm("headerbytes").set(str(struct.calcsize(headerFormat))) points = geo.points() frame_int = ((int(hou.evalParm("frame")) - startFrame) + 1) xyz_size = struct.calcsize('<fff') hou.parm("posbytes").set(str(xyz_size)) seek_offset = max([0, frame_int-1]) * len(points) * xyz_size hou.parm("seekoffset").set(str(seek_offset)) if ((numPoints==len(points)) and (frame_int<=numSamples)): # Seek relative to the current file pos (os.SEEK_CUR==1) pc2File.seek(seek_offset, 1) buffer = pc2File.read(xyz_size * len(points)) positions = numpy.frombuffer(buffer, dtype="f4,f4,f4").copy() positions.dtype.names = ("x", "y", "z") geo.setPointFloatAttribValuesFromString("P", positions) pc2File.close() Quote Link to comment Share on other sites More sharing options...
Owl Posted March 19, 2014 Share Posted March 19, 2014 Hi, dont know if mine is faster, but I used to use this: pcROP.rar maybe it'll help Quote Link to comment Share on other sites More sharing options...
glassman3d Posted April 14, 2014 Author Share Posted April 14, 2014 thanks owl, I will give that a go as well! Quote Link to comment Share on other sites More sharing options...
louiszeifer Posted November 26, 2014 Share Posted November 26, 2014 Hi Owl, your pcROP is not working. The pc2write otl is running a pre and post render script in owl_rop_utils.py module which is not part of your rar file. If I disable these render scripts, the pc2write nodes is tying to run a soho_programm called execute.py which is not part of your rar file, either. Can you please help me with that? Thank you very much, Karsten Quote Link to comment Share on other sites More sharing options...
Owl Posted November 27, 2014 Share Posted November 27, 2014 Hi, Karsten, execute.py is inside of the otl and it should remain there. (extra files tab) pre script is for creation of non existing paths post script is to open export path in system so they aren't esential all you need to do is copy pointcache.py into $HOME/houdiniX.Y/scripts/python/ could you post exact error message you are getitng? Quote Link to comment Share on other sites More sharing options...
