magneto Posted February 24, 2014 Share Posted February 24, 2014 (edited) Hi, I am deleting glue constraints at the SOP level but nothing happens in DOPs. I checked everything 5 times so I am not sure why it doesn't work. The same thing didn't work in DOPs using a SOP solver. What am I missing? Thanks constraints.hip Edited February 24, 2014 by magneto Quote Link to comment Share on other sites More sharing options...
rayman Posted February 24, 2014 Share Posted February 24, 2014 Didn`t have a chance to open your scene, but sometimes unchecking enable sleeping resolves this kind of problems. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted February 24, 2014 Author Share Posted February 24, 2014 Thanks rayman, I have it unchecked already Quote Link to comment Share on other sites More sharing options...
rayman Posted February 24, 2014 Share Posted February 24, 2014 The other thing you need to check when pieces are not moving is collision geometry. If you simulate without the constraint the pieces are not moving again. It is the tube node collision geometry that is causing the problem. Good Luck 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted February 24, 2014 Author Share Posted February 24, 2014 Thanks alot rayman, I didn't realize that. It works now Quote Link to comment Share on other sites More sharing options...
