schiho Posted March 6, 2014 Share Posted March 6, 2014 (edited) Hi, i have a short and simple question, is it possible to deactivate a "static object" in the dop network at a given time? normally nodes have "activation" but not the static object dop. thanks! Edited March 6, 2014 by schiho Quote Link to comment Share on other sites More sharing options...
-HEAVY- Posted March 6, 2014 Share Posted March 6, 2014 you have a seperate activation node or can use a wrangle to set the value of the active Attribute on rigid bodysbut i think you can´t use a static object - cause the static object is defined by the static solver and the rbd goes in to the rbd solver... or maybe you try a Switch to Switch between static and rigd solver... Quote Link to comment Share on other sites More sharing options...
schiho Posted March 8, 2014 Author Share Posted March 8, 2014 It would be nice to see a little example... Quote Link to comment Share on other sites More sharing options...
