vbk!!! Posted March 25, 2014 Share Posted March 25, 2014 Hello, I am trying to follow the crowd tutorial of Guillaume Fradin. During this, he is using one of his tool, a filebatch tool to convert bvh files in bclip/cmd files. I tried the hda but it seems there is a compatibility problem between Linux and Windows. I am on Win7 ... Newbi onPython programming,I am now trying to modify this script to make it work properly on WIndows but I am unable to make something working here is the original script : import os import re import sys def start(node): for file in file_list(node): launch_cmd_on_file(node, file) def get_nb_files(node): nb_files = len(file_list(node)) node.parm('nb_files').set(nb_files) def file_list(node): dir = node.evalParm('directory') pattern = node.evalParm('pattern') return pattern_matching_file_list(dir, pattern) def launch_cmd_on_file(node, file): cmd = node.evalParm('cmd') dir = '/'.join(file.split('/')[0:-1]) cmd = "cd "+dir+';'+cmd+' '+file+';\n' print cmd os.system(cmd) def pattern_matching_file_list(dir, pattern): list = [] for root, dirs, files in os.walk(dir): for file in files: if re.search(pattern, file) is not None: list.append(os.path.join(root,file)) return list On Windows I find a problem with the os.system(cmd) line : I don't think mutiple command works on windows ( or not this way at least). The pattern_matching_file_list function give slash/backslash issue. After some failed tests, I am focusing on a specific directory to understand what is going on. Here is the modified code : import os import re import sys def start(node): for file in file_list(node): launch_cmd_on_file(node, file) def get_nb_files(node): nb_files = len(file_list(node)) node.parm('nb_files').set(nb_files) def file_list(node): dir = node.evalParm('directory') pattern = node.evalParm('pattern') return pattern_matching_file_list(dir, pattern) def launch_cmd_on_file(node, file): cmd = node.evalParm('cmd') # dir = node.evalParm('directory')+'/'.join(file.split('_')[0:-1]) dir = node.evalParm('directory') cmdb = "cd "+ dir cmdc = cmd +' '+ file print cmdb +' '+ cmdc os.system(cmdb) os.system(cmdc) def pattern_matching_file_list(dir, pattern): list = [] for root, dirs, files in os.walk(dir): for file in files: if re.search(pattern, file) is not None: list.append(os.path.join(file)) return list with this code mcbiovision returns it's unable to open .bvh file for reading. the print cmdb +' '+ cmdc return line likes this : cd D:/MOCAP/CMU/01/ mcbiovision 01_14.bvh Of course, if I tape theses 2 commands in a the houdini command line tool, it works as excepted. Why theses 2 commands works when I tape them but don't work when it execute via python ? Could it be beacause of the 2 os.system() ? If yes, how can I use one os.system for 2 commands on Windows ? Thanks for your help Vincent Quote Link to comment Share on other sites More sharing options...
vbk!!! Posted March 25, 2014 Author Share Posted March 25, 2014 os.chdir() instead of os.system() with cd. and complete path for the mcbiovision. Quote Link to comment Share on other sites More sharing options...
