Doum Posted April 7, 2014 Share Posted April 7, 2014 (edited) Hello, I'm trying to link particles created by the pop replicate together, someone can suggest me a workflow to achieve that ? An effect similar to the one done with trail sop + add by attribute id give, but using pop replicate to create trail instead of the trail sop. Thanks Doum Edit : I found a solution, I got to uncheck add ID attribute in the pop replicate and use the add sop by attribute id with the pop replicate stream select in group param. And it's working. Edited April 8, 2014 by Doum 1 Quote Link to comment Share on other sites More sharing options...
