3__ Posted July 5, 2004 Share Posted July 5, 2004 I'm wondering if there's a way to animate the position of swept/railed items in sops, something like the position slider in the object-level path constraint. ideas? -cpb Quote Link to comment Share on other sites More sharing options...
thekenny Posted July 5, 2004 Share Posted July 5, 2004 you have to animate the points of the curve where your profiles are swept/railed. just build your curve on the fly with a few carveSOPs or some other method and you will get what you described. it is very doable. -k Quote Link to comment Share on other sites More sharing options...
3__ Posted July 5, 2004 Author Share Posted July 5, 2004 carve-cut and carve-extract (with divisions) then add does the trick, thanks! now on to non-wiggy swept-object orientation... -cpb Quote Link to comment Share on other sites More sharing options...
