DaveSimmons Posted April 14, 2014 Share Posted April 14, 2014 Hi there, I'm new to Houdini and would love to create a freeze frame effect. Such that I can effectively stop all simulations rotate the camera around all the objects (including a flip fluid and RBD objects) and then resume simulation. I tried using a ROP output driver and then exporting the Sim...and reading that into a new document but am not sure that's the right approach. Any pointers would be greatly appreciated. Thanks,D. Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted April 14, 2014 Share Posted April 14, 2014 To get this done, personally I would run write out the sim at normal speed, then read it the file sequence in, and in a separate file node read in the specific frame you want to freeze on. using a switch, keyframe the switch to switch from the sequence to the static frame. If you want to slow down the sim down to freeze, this will need to be done using chops. 1 Quote Link to comment Share on other sites More sharing options...
Jordan Walsh Posted April 14, 2014 Share Posted April 14, 2014 (edited) or just use a timeshift and use an expression/ animate the value to exactly what you want. If you want to slow it down you can also use a timeblend before this but you need to make sure your geo isnt changing point count between frames for this method to work. Edited April 14, 2014 by Jordan Walsh Quote Link to comment Share on other sites More sharing options...
Solitude Posted April 14, 2014 Share Posted April 14, 2014 Timeblend can work with changing point counts if you have id attribute as well. Quote Link to comment Share on other sites More sharing options...
whodini Posted April 14, 2014 Share Posted April 14, 2014 (edited) lay down a time blend sop and specify your start / end frame range, then add a time shift sop right after that and uncheck integer frames (to get subframe geometry, prevent jittering), and just animate the frame number however you like. Not: if you're going to use this trick with flip fluids just turn off reseeding. I've attached a hip retime_geo.hip Edited April 14, 2014 by rhussain Quote Link to comment Share on other sites More sharing options...
DaveSimmons Posted April 16, 2014 Author Share Posted April 16, 2014 Thanks so much for all your help. And the HIP file rhussian greatly appreciated. I will have dig into it just now. D Quote Link to comment Share on other sites More sharing options...
