multi attractor in pop
grafmed
Anyone having suggestion on
having a source that going to multi attractor in specific order and stays for a few seconds, it changes directions and speed. to clearify, same amount of particles all the time jumping to 1 attractor stays 5 sec jumps to second attractor in different direction stays 7 sec .........jumping to attractor 5.
using H 6.5
just thought of another way. you don't have to use attractors at all - just create several pieces of geometry that will serve as your attractors, plug them in the source pops and make them generate static particles (similar amount on all of them). then you can add a bunch of follow pops and make your moving particles move from place to place by turning on or off the necessary source and follow pops.
