frez Posted April 29, 2014 Share Posted April 29, 2014 I'd like to place hlights along a curve. I know I can use the copy SOP to place geometry like boxes or spheres, but how do I place something at the object level like an hlight?Thanks! Quote Link to comment Share on other sites More sharing options...
wick3dParticle Posted April 30, 2014 Share Posted April 30, 2014 (edited) Hi Frez, A simple way to go about instancing lights is using the object level 'instance' node. Just object-merge your curve inside the instance node or create it directly inside the node. Make sure you point to your light under the instance tab. You can vary your instance attributes such as intensity or color using the instancepoint() expression. I'll attach an example. ~Ilan IGinstanceLights.hipnc Edited April 30, 2014 by wick3dParticle Quote Link to comment Share on other sites More sharing options...
