Iwanz Posted May 8, 2014 Share Posted May 8, 2014 Hello, i'm an Houdini beginner and this is my first post. I'm following a tutorial and i'm get into the problem reported in the post title. Look strange to me because, even if i have a very little comprehension about points cloud, all the pc-import nodes are certainly inside the while-loop. The while-loop condition is given by a constant set to 1. Whit this setup the system give me the error message, and any action I do inside the while-loop result into an endless cooking time (that i can stop only by pressing esc several time). But if i set the constant to 0 or if i detach it from the while-loop the problem disappear. I would like to know where the problem come from. Thanks in advance (and sorry for my English). P.s. I'm on Xubuntu 14.04 whit Houdini 13.0.406. If I run the program by terminal I receive this warning: program compiled against libxml 209 using older 208 (maybe it can depend from this). connections_error.hipnc Quote Link to comment Share on other sites More sharing options...
