Iterating over voxels
Hey Marc, I don't have a current inlinecpp example for that. But the docs have a good section on iterating through volumes and their values.
http://www.sidefx.com/docs/hdk13.0/_h_d_k__volumes.html
This should give you an idea on the functions needed to do that. I'll look at seeing what could be done with the inlinecpp.
-Rick
I believe it should be GU/GU_Detail.h and GU/GU_PrimVolume.h on the HDK side of things.
http://www.sidefx.com/docs/hdk13.0/_g_e_o_2_g_e_o__voxel_translator_8_c-example.html
http://www.sidefx.com/docs/hdk13.0/standalone_2gengeovolume_8_c-example.html
Definitely gonna have to look into it on the inlinecpp side of things.
If i may ask a question kind of related to this topic : can anyone tell me how to properly use a UT_VoxelArrayIteratorV4 to iterate over a SIM_VectorField.
For now what i'm doing is :
UT_VoxelArrayIteratorF myvectorFieldIterator[3];
for (int i = 0; i < 3; i++)
	myvectorFieldIterator[i].setArray(myvectorField->getField(i)->fieldNC());
	myvectorFieldIterator[i].rewind();
and what i would like to do is :
UT_VoxelArrayIteratorV4 myvectorFieldIterator;
myvectorFieldIterator.setArray(myvectorField->getField()->fieldNC());
But it seems i can't set a UT_VoxelArrayV4 to the UT_VoxelArrayIteratorV4 with the setArray() method =/
Edited by narthe
