xtremist999 Posted May 17, 2014 Share Posted May 17, 2014 Hi there, I have a few questions about loading in cache. 1.) How can I load in a specified frame range of some bgeo cache? 2.) Or if I load the entire range in, is there a node that can isolate the frame ranges that I want to use and delete the cache outside those ranges? 3.) Lastly, how can I offset cache along the timeline after loading it in? Thanks! Quote Link to comment Share on other sites More sharing options...
Solitude Posted May 17, 2014 Share Posted May 17, 2014 Timeshift sop can do what you want. 1 / 2 : Just set the file sop to load with $F, and then in the timeshift do clamp($F,10,50) and it will use frames 10-50, holding frame 10 and 50 before and after those frames. You can also use if statements or a switch node afterwards to 'turn it off' 3: clamp($F,10,50)+5 will offset by 5 frames. If you are viewing the timeshift sop, it will only load the frame you are requesting. 1 Quote Link to comment Share on other sites More sharing options...
xtremist999 Posted May 17, 2014 Author Share Posted May 17, 2014 Thanks! I'll give that a shot Quote Link to comment Share on other sites More sharing options...
