FLIP and VDB collision
r1ver
The main issue is that your fluid particles are moving so quickly that they don't ever see the collision volume, which has rather thin walls. The general solution is to make the volume thicker so it traps all possible particles.
Here's an example for your specific issue. Create a volume representing the interior of your cup. Don't scale the volume by -1 in the volume source since the volume represents a void to trap the liquid. I've made it very thick by increasing the exterior band voxels.
This won't work if you need the fluid to slosh out of the cup, but if you just want it to stay in the cup it should work OK.
cup_test_fix.hip
