r1ver Posted May 21, 2014 Share Posted May 21, 2014 Hi, I have a proxy for collision, but i fail to parent the proxy with the real object using the Shelf Tool "Parent". How could I parenty a collision proxy object to a geo? Thanks! parent_test.hip Quote Link to comment Share on other sites More sharing options...
xray Posted August 11, 2014 Share Posted August 11, 2014 Your scene seems to be working fine in 13.0.447, though you may want to change a couple of things: Send the VDB directly to DOPs. You don't need to convert it to volume prim. Set the "offset surface" to 0 in the Static Object DOP. Use a static solver dop instead of an RBD solver for the cup collision. Quote Link to comment Share on other sites More sharing options...
