charleyc Posted May 23, 2014 Share Posted May 23, 2014 Hello I am trying to float some debris on a water surface. I have a buoyancy setup that works great for position that allows me to float on an sdf. However, the orientation of the debris will just freely spin around. I need to to somewhat realistically stay upright based either on the debris shape, or a preset up vector. I have two scenes that I have attached. One is just the buoyancy setup, the other is my feeble attempt at using the orient and an up vector to create a torque force....it is not working Any help would be greatly appreciated. Thanks Charley floating-orient_001.hipncFetching info... floating_001.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
charleyc Posted May 24, 2014 Author Share Posted May 24, 2014 Ok I figured it out. Not sure if it is the most elegant of solutions, but it works. Here is the file if any one is interested. floating-orient_002.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
