more_sweep_problems
3__
Is there a way to stop swept geometry
from rolling 180 degrees on concave
sections of the backbone?
I'm also having problems with reference
point aiming, namely the first and last
item orientation is broken when using
a vertex-offset copy of the backbone as
the reference point input (see attached).
-cpb
sweep_problem.zip
thanks, Edward.
I'm trying to have the ringed side of the
geometry all on the same side so I can run
a cable through it.
when the animation is played the first
item will still flip along its length at seemingly
random frames.
perhaps it needs some vops point normal massaging
(there goes my evening) and a copy sop.
attached is a lighter, playable version.
-cpb
sweep_problem_2.zip
nice. incidentally, how do I get a vector
output from a matrix3 in vops (lookat vop)?
I've looked up the math at euclideanspace.com
and tried it in this case (to cater for a twisted
curve) without success:
heading = atan(m01/m00)
bank = atan(m12/m22)
attitude = asin(-m02)
-cpb
Just use the Extract Transform VOP. Oh wait, that only takes a full 4x4 matrix. So after the look at, append a Matrix3 To Float VOP. Then Append a Float To Matrix VOP. Wire up the matching named outputs and inputs. (leave all the inputs with a number 4 disconnected) Now you can append an Extract Transform VOP after the Float To Matrix VOP.
This is a good candidate for a new custom VOP type. A Extract Matrix3 VOP.
