Undertaker Posted July 17, 2004 Share Posted July 17, 2004 Hello everybody, I'm new to fog shaders and I had a couple of questions : 1/ How do I create a layered fog shader ? For example a ground fog, density fading on Y axis mixed with a noise to randomize the effect a little bit . I believe I have to play with VOPs, as I couldn't find it in VEX standard library. 2/ I would like to create a more sophisticated Image 3D Fog shader, for example add some turbulence, and other effects, do I also have to use VOPs ? I believe these questions have quite the same answer, basicaly I just need some help on the methodology to create a Fog shader. thanks in advance. Julien Quote Link to comment Share on other sites More sharing options...
