[SOLVED] Moving Noise in mantra surface shader
Hi guys,
I'm experiencing a problem with a noise in mantra surface shader. As the noise is created from the objects coordinates, it looks like it's animated, when the object is moving. What I need to achieve is to just have static noise on a sphere, so when the sphere moves, the noise looks the same. I tried plugging in the UV coordinates of the object into position for turbulent noise in shader, but that resulted in having artifacts in UV seams.
How should I approach the problem?
I'm attaching the example file, showing the animation of the texture when rendered
movingTextureNoise.hipnc
Edited by Cake Kid
