define new vop node
Hi there, I've created a material that contains an inlineCode node with some vex inside. I'd like to be able to create a generic version of this node that can be re used but there are a few problems.
when i add inputs to the node they inherit the names of their input, I'd like them to be generic, i.e. "input1" rather than "product" if i connect  the output of a multiply node or "s" if i connect a texture coordinate.
Also as the node just creates code any variables contained within are placed in the resulting code verbatim and if i have many copies of the inlineCode node with the same contents then I get clashing variable names.
Has anyone done this? or does anybody know where to look for docs on createing new vop node templates that are more flexible.
Cheers
jon
