wildon Posted June 30, 2014 Share Posted June 30, 2014 hello guys, i try to mix two kinde of effect. a disintagration effect and the collapsing effect. i want when an object dissappear, the surrounded objects fall. i know how achieve the desintagration, i know how make a collapsing.but i have a issue. my idea is achieve my rbd sim at the frist time and use the result and apply the my desintagration setup. does anyone know how to make an object collide with none of the others during a smimulation ? i means at the begining i need everybody react as a regular RBD but at the certain time, certain object vanishing. i hope i'm clear thx Quote Link to comment Share on other sites More sharing options...
anim Posted June 30, 2014 Share Posted June 30, 2014 you can either delete the DOP object using Delete DOP with activation set to some expression like $FF>100 or if it's part of packed fragments, just delete it inside of the SOP Solver Quote Link to comment Share on other sites More sharing options...
wildon Posted June 30, 2014 Author Share Posted June 30, 2014 thanx Anim, i try to do like you say, i think i don't understand something because nothing happen. you know why? thx table.hipFetching info... Quote Link to comment Share on other sites More sharing options...
wildon Posted June 30, 2014 Author Share Posted June 30, 2014 (edited) Ok i'm stupid! just use a multisolver everything work almost fine... i animate my disparition like that https://vimeo.com/99555694 but when a run everthing (sop solver and rbd Solver) more piece disapearing. https://vimeo.com/99555808 no body have a clue? thanx. delete_from_bullet.hipFetching info... Edited June 30, 2014 by wildon Quote Link to comment Share on other sites More sharing options...
rayman Posted July 1, 2014 Share Posted July 1, 2014 (edited) When you delete a piece, all other pieces after it will shift their order, so their point id will be different from the original. Thats why only first piece is correctly deleted. Instead you have to store each piece id as attribute and use it to get attributes from driver geometry. Simplest way is to use name attribute with wrangle node instead of point: inside sop solver in dops remove point and delete nodes. connect dop_geometry to first, and object_merge1 to second input. create attribWrangle and set it to run over points. add this code: int drpt = findattribval(@OpInput2, "point", "name", s@name, 0); i@disapear = point(@OpInput2,"disapear",drpt); if(i@disapear==0){ removepoint(0,@ptnum); } Edited July 1, 2014 by rayman Quote Link to comment Share on other sites More sharing options...
wildon Posted July 1, 2014 Author Share Posted July 1, 2014 thank you Rayman. it working but i confess i don't understand why... For me the wrangler attribute do exactly the samething that my point node with the "attribute to match" and the delete. I compare my delete node wich your wrangler attribute and they sort the points exactly the sameway. It working is the most important now but i'm a little bit frustrated to don't understand... Quote Link to comment Share on other sites More sharing options...
rayman Posted July 1, 2014 Share Posted July 1, 2014 It`s not the same thing. You are thinking in SOP context instead of DOP. I`ll give you simple example. Let`s say you have 5 points with numbers from 0 to 4. In SOP: On first frame you just want to delete pt2 so you set disapear attribute to 0. In DOP: On the first frame all points will take correct attributes from SOPs. DOP pt0 from SOP pt0 DOP pt1 from SOP pt1 DOP pt2 from SOP pt2 DOP pt3 from SOP pt3 DOP pt4 from SOP pt4 Then delete node will delete DOP pt2, and then all the poins after pt2 will shift their ids: original DOP pt3 will became DOP pt4 original DOP pt4 will became DOP pt5 On the second frame attributes won`t be transferred corectly: DOP pt0 from SOP pt0 DOP pt1 from SOP pt1 DOP pt2 from SOP pt2 DOP pt3 from SOP pt3 which is actually equal to: original DOP pt0 from SOP pt0 original DOP pt1 from SOP pt1 original DOP pt3 from SOP pt2 original DOP pt4 from SOP pt3 so the point node will copy disapear attribute from original pt2 to original pt3 and delete node will delete it. 4 Quote Link to comment Share on other sites More sharing options...
wildon Posted July 2, 2014 Author Share Posted July 2, 2014 thanx for your explaination. is a littel bit more clear Quote Link to comment Share on other sites More sharing options...
