rayt Posted July 15, 2014 Share Posted July 15, 2014 A question about wires and cloth. I have a sim where I have a piece of cloth in the wind with two wires, spring constrained to the bottom corners. The wires are fixed with a pin constraint and the points connected to the cloth are fixed with the spring constraint. At this point, as the cloth sims, the wires pull on the cloth, causing the corners to stretch. The intention is to have the wire stretch and move based on the cloth. What am i missing in order to have the cloth influence the wires instead of the other way around (which is what is happening currently). Any help in this would be appreciated. I can potentially add scren shots if needed, but I cannot attach hip files. Thanks in advance, Ray T. Quote Link to comment Share on other sites More sharing options...
