lookup vop?
After struggling with the ramp parameter's lack of bezier handles, with catmull-rom always wanting to put a hump right in the place I'd like to smooth out, I've decided that it might be easier to input my own lookup values.
While there's a lookup cop, and lookup chop, there is unfortunately no lookup vop.  Is there a vop or vex command I'm overlooking? If not, what could I search for to find the concept of how to implement some lookup code in a vex snippet?
An example file is attached below if anyone would like to offer any ideas.
(I'd like to keep all this in an attrib vop if possible, as eventually I'd like to implement it in a shader as a companion to the sop version.  So I haven't used the channel editor->parameter->chf() workaround here.)
lookup_vop.hipnc
there is ch() function in VEX you can use (so Inline VOP or Snippet VOP)
there you can specify time as well so you can lookup channel at certain time
you can use chf(), chv(), ... to get float, vector, ... parms directly
Though, Is there any way to remap to another vops value?
what do you mean by that?
EDIT: oh, I see your file
for looking up you need a function like y=f(x), where you supply x and you'll get y
so arbitrary single value will not do
if your "value" (function)  is noise, simply plug your VALUE_TO_CHANGE as a position input to the noise to lookup the noise value, etc, you simply need the function
Edited by anim
Oh, I just used the noise as a simple example... in another larger setup I had a value coming in that I really wanted to modify based on another calculated value, like one would with lookup cop or chop
If that functionality wasn't built in, I thought it might be a good chance to look into the math behind a lookup operation, but I have yet to find a good explanation.
as I said you need a function
so as CHOP channel is essentially a function over time or COP collumn/row is a function over x or y, you can directly lookup the value
but for SOP attributes you have just values on components so no function unless it's directly VOP function or you decide that you want to sample values over certain path on the surface
so for example if you have values on the curve that you want to sample, you can use primuv() VEX/Primitive Attribute VOP to lookup the value based on u coordinate or for NURBS based on u/v
otherwise I don't really know what you expect to lookup the value by
if you assume that the geo is grid (like COPs, or line like CHOPS) you can directly sample based on x or y or z axis and the closest surface using xyzdist() function
the same if it's not a grid and you want to lookup value from the closest surface
you can as well have your "value" in the volume and lookup that using volumesample()
Edited by anim
