Calculating velocity of points being moved in a VOP SOP in a Solver
Example file attached. I'm trying to calculate the velocity of the points, where I would expect to see the color move from black to white and then back to black as they settle. Instead I don't seem to be able to look up both the current and last frame's positions properly.
I'm sure this is simple, what am I doing wrong here?
velocity_color.hipnc
you are taking input1 and comparing to previous frame, so because the points are further and further from their positions in input1, your length will return bigger number therefore white
you literally just need to compare P before your displacement and after to compute velocity (divide by timestep to make it per second)
then you can convert v to color after solver
velocity_color_fix.hipnc
