FR3D Posted August 1, 2014 Share Posted August 1, 2014 (edited) EDIT The problem comes from the clusterpoint node which seems to add a duplicated piece name with no path: I am trying to do a bullet cluster sim. i am having a problem when doing the glue network. For some reason the connectadjacentpiece node doesn't want to compute on one of the cluster created. Whatever the number of cluster, there is always one cluster that will not be computed by the node. It seems that the problem isn't the foreach as when i try to select the problematic group and apply the connadjpiece outside the foreach, i still get no connection computed for that particular cluster in this particular example bullet_cluster.hipnc i added a partition to debug and see which cluster doesn't compute. You can change the cluster group and see that it works for all other cluster thank you for helping. Edited August 1, 2014 by FR3D Quote Link to comment Share on other sites More sharing options...
FR3D Posted August 1, 2014 Author Share Posted August 1, 2014 so i fixed it by using a simple cluster and transfer attribute it works flawlessly bullet_cluster_fixed.hipnc Quote Link to comment Share on other sites More sharing options...
cowboy71 Posted November 17, 2015 Share Posted November 17, 2015 Hey there, So I came across your post while searching for Bullet Glue cluster. I have a little bit of a complex problem which maybe you might know a solution. In my scene there is a house which eventually gets destroyed by high winds, I have a particle system which collides with the geometry of the house forcing it to be ripped apart. I have a glue network which is being dissolved by a separate point cloud I'm moving through the house. I wanted to be able to dissolve the glue network with points so I could have some pieces get sucked away by a wind force right before the actual particles come and collide with the geometry and carry the pieces up. My problem is all of the house gets released (glue) when the point cloud rolls through and I can't get any clusters. I'm probably working this wrong, but everything has been working great up until now. Seems like if I wanted clusters I couldn't dissolve the entire network. Anyway, hope that makes sense. Thanks Quote Link to comment Share on other sites More sharing options...
