bandini Posted August 5, 2014 Share Posted August 5, 2014 Hoping for a quick example file. I am trying to create an intersecting junction between two nurbs cylinders, hopefully with some smoothing at the intersection. Anyone want to throw an example file my way? Quote Link to comment Share on other sites More sharing options...
anim Posted August 5, 2014 Share Posted August 5, 2014 Surfsect SOP is your friend, it even does blending surfsect_example.hip Quote Link to comment Share on other sites More sharing options...
bandini Posted August 5, 2014 Author Share Posted August 5, 2014 Hey Tomas (or anyone else out there). Do you know why surfsect does not work the same as yours in my file here? Pipe_01.hip Quote Link to comment Share on other sites More sharing options...
anim Posted August 5, 2014 Share Posted August 5, 2014 (edited) set mode to Intersect instead of Union then maybe set 2D Tolerance to 0.05 for your case, to just get proper hole carved in both tubes but overall if you notice some problems in resulting mesh try to tweak the tolerance parms and play with Radius for blending Edited August 5, 2014 by anim Quote Link to comment Share on other sites More sharing options...
