batch-sim of DOP I/O with hython
borisb2
Hi.
I am setting up batch-simulations with houdini.
For all geometry-ROPs (particles, RBD) as well as mantra this workflow seems to work pretty well:
renderNode = hou.node(sys.argv[2])
renderNode.render(frame_range=(frameStart,frameEnd), verbose=True)
This will be called with a hython command and some args from the render-manager (sys.argv[2] is the path to the ROP ) .. so far so good.
But with volumes this doesnt seem to work. When setting up a pyro sim there's also the DOP I/O and DOP-Import node to visualize and render the volume.
Testing in python shell something like
"renderNode = hou.node('/obj/import_pyro_build/import_pyrofields')" reveals that there is no .render method available. So "renderNode.render()" can't work anymore and fails on the farm. Sure I could attach a Geometry-ROP to the DOP I/IO but that doesnt seem to be the right workflow.
What am I doing wrong? How do you cache out volumes with python? What about .sim files?
Edited by borisb2
hmm.. I guess the answer is to not use DOP I/O for caching out but rather attach a ROP to the DOP-Import node and a file-node to read back the sim.
That seems to work on the farm and for render .. weird
