renderpipe Posted August 4, 2004 Share Posted August 4, 2004 hello everybody, I am having big headache with rand(). I want to randomize extrusion of edges or translation of points but me not understand how. I make grid sop and I select all edges on far right (3 edges) and I append polyextrude sop. Now I want to extrude these 3 edges in x direction but I don't want them all to extrude same time. I want to randomize the extrusion so maybe 1st edge is extruded 1.0 2nd edge is extruded 1.5, etc. I also tried using points and connecting point sop with no luck when trying to translate random points.. I want to do animation so they start extruding and different times but end up in same place like at frame 100. I thought clamp would be good idea for this animation but I am lost. Any help you give makes me much thankful, Perry Quote Link to comment Share on other sites More sharing options...
Keyframe Posted August 5, 2004 Share Posted August 5, 2004 I want to do animation so they start extruding and different times but end up in same place like at frame 100. I thought clamp would be good idea for this animation but I am lost. 13048[/snapback] Heya renderpipe, I think the trick in this case is that the polyextrude SOP will no allow you to easily cook individual edge extrusions [as far as I can tell]. If you are dealing with a simple-ish case of 3 faces that need to get animated, I would suggest putting down three separate polyextrude SOP, and animating their values by hand [to affect only the desired edges]. I think the trick in this case, would be to isolate the individual edges that you wish to animate, extrude them individually, then merge them into one big piece of geometry. As a side note, this approach sets off a few red flags in my head, as you will probably run into a situation where your point count is likely to change midway through the animation [when the extrution is 0 length - a facet sop down the chain may consolidate the points] which is never a good thing. Hope this helps a little bit, Cheers, G Quote Link to comment Share on other sites More sharing options...
Keyframe Posted August 5, 2004 Share Posted August 5, 2004 Heya renderpipe, Just had a thought, if the above does not work for you, you might want to try the approach below. simply save the code segment into a file, and source it via the textport (make sure you source it into a valid piece of geometry though). The trick in this case is that the line segment has a predictable point order, which allows for an easy way of breaking the curve into smaller segments. Applying a similar procedure to a grid is also possible, but the expression for the deletion will be slightly more involved. Let me know if this sheds some light on the matter. Cheers, G # Automatically generated script: Thursday August 05, 13:26 \set noalias = 1 set saved_path = `execute("oppwf")` opcf /obj/model # Node add1 opadd -n add add1 oplocate -x 1.86789 -y 1.58341 add1 opparm add1 stdswitcher ( 0 0 ) keep ( off ) points ( 1 ) remove ( off ) switcher ( 0 0 ) prims ( 1 ) group ( "" ) add ( all ) inc ( 2 ) attrname ( "" ) closedall ( off ) usept0 ( on ) pt0 ( 0 0 0 ) weight0 ( 1 ) prim0 ( "" ) closed0 ( off ) chlock add1 -*chautoscope add1 -*opcolor -c 0.7 0.7 0.7 add1 opset -d off -r off -h off -f off -y off -t off -l off -s off -u off -c off -C off -p off -e on -b off add1 opcf /obj/model # Node copy1 opadd -n copy copy1 oplocate -x 1.86789 -y 0.458413 copy1 opparm copy1 sourceGrp ( "" ) templateGrp ( "" ) stdswitcher ( 0 0 ) ncy ( 100 ) nml ( on ) cum ( on ) xOrd ( srt ) rOrd ( xyz ) t ( 0 0 -0.05 ) r ( 0 0 0 ) s ( 1 1 1 ) p ( 0 0 0 ) scale ( 1 ) vlength ( on ) newg ( off ) preservegroups ( off ) copyg ( 'copyGroup$CY' ) stamp ( off ) param1 ( "" ) val1 ( 0 ) param2 ( "" ) val2 ( 0 ) param3 ( "" ) val3 ( 0 ) param4 ( "" ) val4 ( 0 ) param5 ( "" ) val5 ( 0 ) param6 ( "" ) val6 ( 0 ) param7 ( "" ) val7 ( 0 ) param8 ( "" ) val8 ( 0 ) param9 ( "" ) val9 ( 0 ) param10 ( "" ) val10 ( 0 ) param11 ( "" ) val11 ( 0 ) param12 ( "" ) val12 ( 0 ) param13 ( "" ) val13 ( 0 ) param14 ( "" ) val14 ( 0 ) param15 ( "" ) val15 ( 0 ) param16 ( "" ) val16 ( 0 ) param17 ( "" ) val17 ( 0 ) param18 ( "" ) val18 ( 0 ) param19 ( "" ) val19 ( 0 ) param20 ( "" ) val20 ( 0 ) param21 ( "" ) val21 ( 0 ) param22 ( "" ) val22 ( 0 ) param23 ( "" ) val23 ( 0 ) param24 ( "" ) val24 ( 0 ) param25 ( "" ) val25 ( 0 ) param26 ( "" ) val26 ( 0 ) param27 ( "" ) val27 ( 0 ) param28 ( "" ) val28 ( 0 ) param29 ( "" ) val29 ( 0 ) param30 ( "" ) val30 ( 0 ) param31 ( "" ) val31 ( 0 ) param32 ( "" ) val32 ( 0 ) param33 ( "" ) val33 ( 0 ) param34 ( "" ) val34 ( 0 ) param35 ( "" ) val35 ( 0 ) param36 ( "" ) val36 ( 0 ) param37 ( "" ) val37 ( 0 ) param38 ( "" ) val38 ( 0 ) param39 ( "" ) val39 ( 0 ) param40 ( "" ) val40 ( 0 ) param41 ( "" ) val41 ( 0 ) param42 ( "" ) val42 ( 0 ) param43 ( "" ) val43 ( 0 ) param44 ( "" ) val44 ( 0 ) param45 ( "" ) val45 ( 0 ) param46 ( "" ) val46 ( 0 ) param47 ( "" ) val47 ( 0 ) param48 ( "" ) val48 ( 0 ) param49 ( "" ) val49 ( 0 ) param50 ( "" ) val50 ( 0 ) doattr ( off ) setpt ( * ) setprim ( "" ) setvtx ( "" ) mulpt ( "" ) mulprim ( "" ) mulvtx ( "" ) addpt ( "" ) addprim ( "" ) addvtx ( "" ) subpt ( "" ) subprim ( "" ) subvtx ( "" ) chlock copy1 -*chautoscope copy1 -*opcolor -c 0.7 0.7 0.7 copy1 opset -d off -r off -h off -f off -y off -t off -l off -s off -u off -c off -C off -p off -e on -b off copy1 opcf /obj/model # Node add2 opadd -n add add2 oplocate -x 1.86789 -y -0.666587 add2 opparm add2 stdswitcher ( 1 1 ) keep ( off ) points ( 1 ) remove ( off ) switcher ( 0 0 ) prims ( 1 ) group ( "" ) add ( all ) inc ( 2 ) attrname ( "" ) closedall ( off ) usept0 ( off ) pt0 ( 0 0 0 ) weight0 ( 1 ) prim0 ( * ) closed0 ( off ) chlock add2 -*chautoscope add2 -*opcolor -c 0.7 0.7 0.7 add2 opset -d off -r off -h off -f off -y off -t off -l off -s off -u off -c off -C off -p off -e on -b off add2 opcf /obj/model # Node delete1 opadd -n delete delete1 oplocate -x 1.86789 -y -1.79159 delete1 chblockbegin chadd -t 0 0 delete1 rangeend chkey -t 0 -v 0 -m 0 -A 0 -F '$N' delete1/rangeend chkey -t 0 -v 0 -m 0 -a 0 delete1/rangeend chblockend opparm delete1 group ( "" ) negate ( keep ) entity ( point ) geotype ( all ) stdswitcher ( 0 0 0 0 ) groupop ( pattern ) filter ( 1 ) pattern ( '`param("segment", 0)`-`param("segment", 0)+1`' ) range ( 0 rangeend ) select ( 1 2 ) boundtype ( usebbox ) size ( 1 1 1 ) t ( 0 0 0 ) dir ( 0 0 1 ) angle ( 180 ) camerapath ( "" ) affect ( 1 ) degenerate ( off ) zaf ( off ) doopen ( off ) tol ( 0.001 ) removegrp ( on ) keeppoints ( off ) chlock delete1 -*chautoscope delete1 -*opcolor -c 0.7 0.7 0.7 delete1 opset -d off -r off -h off -f off -y off -t off -l off -s off -u off -c off -C off -p off -e on -b off delete1 opcf /obj/model # Node copy2 opadd -n copy copy2 oplocate -x 1.86789 -y -4.04159 copy2 chblockbegin chadd -t 0 0 copy2 val1 chkey -t 0 -v 0 -m 0 -A 0 -F '$CY-1' copy2/val1 chkey -t 0 -v 0 -m 0 -a 0 copy2/val1 chblockend opparm copy2 sourceGrp ( "" ) templateGrp ( "" ) stdswitcher ( 1 1 ) ncy ( 100 ) nml ( on ) cum ( on ) xOrd ( srt ) rOrd ( xyz ) t ( 0 0 0 ) r ( 0 0 0 ) s ( 1 1 1 ) p ( 0 0 0 ) scale ( 1 ) vlength ( on ) newg ( off ) preservegroups ( off ) copyg ( 'copyGroup$CY' ) stamp ( on ) param1 ( segment ) val1 ( val1 ) param2 ( "" ) val2 ( 0 ) param3 ( "" ) val3 ( 0 ) param4 ( "" ) val4 ( 0 ) param5 ( "" ) val5 ( 0 ) param6 ( "" ) val6 ( 0 ) param7 ( "" ) val7 ( 0 ) param8 ( "" ) val8 ( 0 ) param9 ( "" ) val9 ( 0 ) param10 ( "" ) val10 ( 0 ) param11 ( "" ) val11 ( 0 ) param12 ( "" ) val12 ( 0 ) param13 ( "" ) val13 ( 0 ) param14 ( "" ) val14 ( 0 ) param15 ( "" ) val15 ( 0 ) param16 ( "" ) val16 ( 0 ) param17 ( "" ) val17 ( 0 ) param18 ( "" ) val18 ( 0 ) param19 ( "" ) val19 ( 0 ) param20 ( "" ) val20 ( 0 ) param21 ( "" ) val21 ( 0 ) param22 ( "" ) val22 ( 0 ) param23 ( "" ) val23 ( 0 ) param24 ( "" ) val24 ( 0 ) param25 ( "" ) val25 ( 0 ) param26 ( "" ) val26 ( 0 ) param27 ( "" ) val27 ( 0 ) param28 ( "" ) val28 ( 0 ) param29 ( "" ) val29 ( 0 ) param30 ( "" ) val30 ( 0 ) param31 ( "" ) val31 ( 0 ) param32 ( "" ) val32 ( 0 ) param33 ( "" ) val33 ( 0 ) param34 ( "" ) val34 ( 0 ) param35 ( "" ) val35 ( 0 ) param36 ( "" ) val36 ( 0 ) param37 ( "" ) val37 ( 0 ) param38 ( "" ) val38 ( 0 ) param39 ( "" ) val39 ( 0 ) param40 ( "" ) val40 ( 0 ) param41 ( "" ) val41 ( 0 ) param42 ( "" ) val42 ( 0 ) param43 ( "" ) val43 ( 0 ) param44 ( "" ) val44 ( 0 ) param45 ( "" ) val45 ( 0 ) param46 ( "" ) val46 ( 0 ) param47 ( "" ) val47 ( 0 ) param48 ( "" ) val48 ( 0 ) param49 ( "" ) val49 ( 0 ) param50 ( "" ) val50 ( 0 ) doattr ( off ) setpt ( * ) setprim ( "" ) setvtx ( "" ) mulpt ( "" ) mulprim ( "" ) mulvtx ( "" ) addpt ( "" ) addprim ( "" ) addvtx ( "" ) subpt ( "" ) subprim ( "" ) subvtx ( "" ) chlock copy2 -*chautoscope copy2 -*opcolor -c 0.7 0.7 0.7 copy2 opset -d on -r on -h off -f off -y off -t off -l off -s off -u off -c off -C on -p on -e on -b off copy2 opcf /obj/model # Node polyextrude2 opadd -n polyextrude polyextrude2 oplocate -x 1.86789 -y -2.91659 polyextrude2 chblockbegin chadd -t 0 0 polyextrude2 ltx chkey -t 0 -v 0 -m 0 -A 0 -F 'rand(param("segment",0))*$F/100' polyextrude2/ltx chkey -t 0 -v 0 -m 0 -a 0 polyextrude2/ltx chblockend opparm polyextrude2 group ( p0-1 ) stdswitcher ( 0 0 0 0 ) lrst ( srt ) lxyz ( xyz ) lt ( ltx 0 0 ) lr ( 0 0 0 ) ls ( 1 1 ) inset ( 0 ) localsym ( symmnone ) keepshared ( off ) grst ( srt ) gxyz ( xyz ) gt ( 0 0 0 ) gr ( 0 0 0 ) gs ( 1 1 1 ) divs ( 2 ) outputfront ( on ) outputback ( off ) outputside ( on ) delzeroareasides ( off ) delsharedsides ( on ) consolidate ( all ) newg ( off ) frontgrp ( extrudeFront ) backgrp ( extrudeBack ) sidegrp ( extrudeSide ) chlock polyextrude2 -*chautoscope polyextrude2 -*opcolor -c 0.7 0.7 0.7 polyextrude2 opset -d off -r off -h off -f off -y off -t off -l off -s off -u off -c off -C off -p off -e on -b off polyextrude2 opcf /obj/model opcf /obj/model opwire -n add1 -0 copy1 opcf /obj/model opwire -n copy1 -0 add2 opcf /obj/model opwire -n add2 -0 delete1 opcf /obj/model opwire -n polyextrude2 -0 copy2 opcf /obj/model opwire -n delete1 -0 polyextrude2 opcf $saved_path Quote Link to comment Share on other sites More sharing options...
renderpipe Posted August 5, 2004 Author Share Posted August 5, 2004 Hello Keyframe, Thank you for reply. I tried poly extrusions with groups selection and it works ok but I have to create many groups and polyextrusions for many variations. It's ok though. For the script example you posted, I need little bit more help. I never source text file before so I dunno what to do. I save your script to my d:\test.txt. In texport I get error can't open d:\test.txt Is there special place I must put this file? with special extension? I not understand I need valid geometry. Are you saying in textport I should cd to valid geometry folder? I check help source but it no say anything where to put file. Thank you for help Quote Link to comment Share on other sites More sharing options...
Keyframe Posted August 5, 2004 Share Posted August 5, 2004 I save your script to my d:\test.txt. In texport I get error can't open d:\test.txt 13067[/snapback] Heya Renderpipe, What I would do, under the windows platform, is first verify that the file does in fact exist in the location that you specified. Also ensure that it didn't pickup some funky extension that windows hides on certain systems. I've often saved files with a certain extension only to find out that windows decided to attach a different extension to it. Just in case I made a mistake. As far as sourcing the file, you would need to create a geometry object (call it "model"), open up a textport, type "cd /obj/model/", and then in the textport, type "source foo", where foo is the full path to the file that you've created above. Once the nodes are created, scrub the time line. Let me know if this setup points you in the right direction. Cheers, G Quote Link to comment Share on other sites More sharing options...
renderpipe Posted August 5, 2004 Author Share Posted August 5, 2004 hello, You are rocking! Thank you very much for help. I am able to source your script and play the animation. I will now study this. Thank you very much for assistance. Perry Quote Link to comment Share on other sites More sharing options...
