Delete by Expression: Rotation along the X axis
$PR is the primitive number. That has nothing to do with rotation.
Do your points have a "rot" attribute, for example from particles?
If you generate a rest frame of reference by using an "up" vector and an orientation vector you may be able to delete based on some threshold derived from the deviation from the frame of reference.
