rayman Posted February 11, 2015 Share Posted February 11, 2015 In fact, it intrigues me were really is installed the main application and related files?, since the files I have inside /Applications/Houdini 13.0.582 are so lightweight… /Library/Frameworks/Houdini.framework/ 1 Quote Link to comment Share on other sites More sharing options...
cristobalvila Posted February 11, 2015 Share Posted February 11, 2015 Thank you so much, Rayman! Just to be sure that I didn't broke something… I placed both files here: /Library/Frameworks/Houdini.framework/13.0.582/Resources/houdini/dso/sop_pathdeform.dylib /Library/Frameworks/Houdini.framework/13.0.582/Resources/houdini/config/Icons/SOP_path_deform.svg It's that right? THANKS! Quote Link to comment Share on other sites More sharing options...
goldleaf Posted February 11, 2015 Share Posted February 11, 2015 You could actually put it in your home dir Houdini preferences folder, which on the Mac is at ~/Library/Preferences/houdini/dso though if you build an hcustom plugin I usually puts the DSO in that directory. 1 Quote Link to comment Share on other sites More sharing options...
cristobalvila Posted February 11, 2015 Share Posted February 11, 2015 Yeah! Thanks Goldleaf! I will save alias to all those directories, since they are really useful! Big thanks Quote Link to comment Share on other sites More sharing options...
