Hi guys,
Can someone be so kind and tell me whats wrong with this...
    GA_RWAttributeRef weightIdx = gdp->findAttribute(GA_ATTRIB_POINT, "weightIndex");
    GA_RWAttributeRef pointIdx = gdp->findAttribute(GA_ATTRIB_POINT, "pointIndex");
    GA_RWHandleV3 wIdx;
    GA_RWHandleV3 pIdx;
    if (!weightIdx.isValid())
        weightIdx = gdp->addFloatTuple(GA_ATTRIB_POINT, "weightIndex", 3);
        wIdx = GA_RWHandleV3(weightIdx);
    if (!pointIdx.isValid())
        pointIdx = gdp->addFloatTuple(GA_ATTRIB_POINT, "pointIndex", 3);
        pIdx = GA_RWHandleV3(pointIdx);
It compiles just fine but when It throws always segmentation fault, but when i do this
    GA_RWHandleV3 wIdx(gdp->findAttribute(GA_ATTRIB_POINT, "weightIndex"));
    GA_RWHandleV3 pIdx(gdp->findAttribute(GA_ATTRIB_POINT, "pointIndex"))
it works just fine, everything's the same except I add the attributes with nodes of course.
What's the difference?
Also how can I get a Handle for arbitrary sized float Tuple attribute like 9 or something, do I need a Handle to set it?  Can I just use GA_RWAttributeRef?
Edited by captain
If the weightIndex/pointIndex attributes already exist, then you fail to initialize wIdx and pIdx.
You can probably do it less lines of (untested) code like
// addFloatTuple will do nothing if the attribute already exists
GA_RWHandleV3 wIdx(gdp->addFloatTuple(GA_ATTRIB_POINT, "weightIndex", 3));
if (wIdx.isInvalid())
    return; // failed to add *new* weightIndex attribute
To deal with non-specific tuple sizes, use a scalar handle like GA_RWHandleF and specify the tuple component when you call get/set.
