sky Posted August 7, 2004 Share Posted August 7, 2004 Hi, I wanna know if there is a way of how to apply different parameter values per particle from a same shader. (ex) I want to apply different range of texture sequence file and different some value of a shader parameter. Thanks in advance... Quote Link to comment Share on other sites More sharing options...
sibarrick Posted August 8, 2004 Share Posted August 8, 2004 Add attributes with the same name as the parameter you are trying to affect and set the values to want you want. Quote Link to comment Share on other sites More sharing options...
sky Posted August 8, 2004 Author Share Posted August 8, 2004 Hi sibarrick Thanks for reply, would you explain more detail it ? I wonder what I do it after when I add attribute set value. Added attribute automatically affect to a shader in SHOP ? How can I add attribute ? I'd appreciate it if you explain it with simple example or network. Thanks in advance Quote Link to comment Share on other sites More sharing options...
