pata Posted September 13, 2014 Share Posted September 13, 2014 Hello! I am using form some time 3D max and I have some problem with textures. Precisely with Unwrap modificator. With simple shapes there is no problem, its not that difficult to do map. But last time I was trying to do the map for plane f16. Plane was almost all in one piece. And I had problem to do nice looking map. Do you have some method to do good map form the complicated shapes? Quote Link to comment Share on other sites More sharing options...
romanus Posted September 19, 2014 Share Posted September 19, 2014 http://www.raylightgames.com/xrayunwrap/index.html - 13€ and you can unwrap everything you want with few clicks... we use it a lot! If you want to spend more money - http://www.uvlayout.com/ Cheers! Quote Link to comment Share on other sites More sharing options...
jrockstad Posted September 22, 2014 Share Posted September 22, 2014 Yes, I will vouch for UVLayout as well - definitely the most painless way to get good UVs in a reasonable amount of time that I've encountered so far. A bit pricey but worth it for the time and hassle it can save you... I'd definitely recommend checking out the demo version. Quote Link to comment Share on other sites More sharing options...
pata Posted September 23, 2014 Author Share Posted September 23, 2014 Seems to be great! Let's try ! Thanks! Quote Link to comment Share on other sites More sharing options...
