Exporting OBJs to .IGS or .IGES
bigwil357
Hello!
I am having an issue with Exporting OBJ's to .IGES or IGS file format.  I usually try to work solely inside Houdini, and I have actually never had the need to export anything. I usually just lay around with Pyro. Now that I need to for a job I am having quite a delima. I have been given .obj files of a car window(s).
I import the file directly from the file menu. The files actually have 4 different windows, but it just comes in as one mesh.
In modo, I have the choice to import the file as 4 different meshes, In houdini i do not see this option. anyways...
I then select the primitives on the windows that I dont want and delete them (dissolve because I cannot select them as individual meshes)
Make a file node, right click on save geometry, and then Nothing.
What am I doing wrong? How do I export these files? I have tried to look everywhere before I created this forum. Any help?
