nicholas_yue Posted September 18, 2014 Share Posted September 18, 2014 Hi, I am prototyping a SOP which generates UVs (2D) using a sampling algorithm Here is what I did in the cook (1) clearAndDestroy() (2) appendVertexBlock(nSamples) (3) addFloatTuple(GA_ATTRIB_VERTEX, "suv", 2) (4) getVertexRange() // for use subsequently (5) set up UT_ValArray<fpreal32> suvResult (6) append data via suvResult.append(resultIter->x) in a loop finally (7) setAttributeFromArray(suvAttrib,vertexRange,suvResult) When I look at the SOP's spreadsheet, I can see the rows matches nSamples but they are all empty Is that because vertex need to reference a point (Point Num) so I'd have to add at least a dummy point ? How would one associate (programmatically) a vertex to the point ? Cheers Quote Link to comment Share on other sites More sharing options...
edward Posted September 18, 2014 Share Posted September 18, 2014 I don't know that the spreadsheet looks at unattached vertices at all. By definition, a vertex is a "point reference that resides in a primitive". See here for the typical polygon case: http://www.sidefx.com/docs/hdk13.0/_h_d_k__geometry__intro.html#HDK_GeometryIntro_AddingPrimitive 1 Quote Link to comment Share on other sites More sharing options...
nicholas_yue Posted September 19, 2014 Author Share Posted September 19, 2014 I don't know that the spreadsheet looks at unattached vertices at all. By definition, a vertex is a "point reference that resides in a primitive". See here for the typical polygon case: http://www.sidefx.com/docs/hdk13.0/_h_d_k__geometry__intro.html#HDK_GeometryIntro_AddingPrimitive Thanks for that Edward, using that example code as a based, I created a dummy primitive with a single dummy point and added all the sampling UV vertex attribute with all the vertices referencing the same single point and the UV data shows up prim_poly_ptr->appendVertex(first_ptoff) Cheers Quote Link to comment Share on other sites More sharing options...
