CiaranM Posted September 23, 2014 Share Posted September 23, 2014 Hi, simple question here. Setting up a simple RBD packed object emitter is very straighforward using a SOP solver, following the example on the helpcard...see attached But, I'm not quite sure how to set up the DOP network when I want to have multiple emitters with different SOP sources. Do I merge different multisolver branches, or merge the sources before running through the multisolver - in which case I need a SOP solver for each DOP object? Any help appreciated! emit_multiple_packed_RBD.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
CiaranM Posted September 23, 2014 Author Share Posted September 23, 2014 Found a solution described here: http://forums.odforce.net/topic/20915-emit-rbd-problem/ but am interested in other methods too! emit_multiple_packed_RBD_working.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
