Using Edge force with particles in 13
J_spad
Hi all! So I am trying to get some particles in 13 to follow a curve. I know there is a tool but it gives the particles a distinctive cylinder shape. I tried to implement the example here with the new particle system with little success  How would I implement the same edge force method in 13?
James
  • 2 weeks later...
I didn't look your solution.
But you can simply use pointwrangle or attribwrangle and set v to edgeforce. By default POPDOP will inherit it.
here is code:
@v=point(@OpInput1, "edgef", @ptnum) * point(@OpInput1, "edge_dir", @ptnum);
Edited by Pradeep Barua
