builduicode and uiparse ?
They're actually very old apps, and rather low-level at that.
uiparse will display a .ui file (assuming it has a window defined somewhere, and the command "OPEN windowname;" in the .ui file).
builduicode generates a .C/h class framework from a .ui file, generating UI_Values, callbacks and UI_Feel pointers for all named values and gadgets.
Unless you're coding .ui files directly, they aren't of much use.
