Pls help. Proper way to continue simulation?
poppy
So, I need to continue simulation after what I left of.
I generated last 5 sim files using explicit cache.
I was following Alessandro's tutorial. It worked on test, but not in real sim.
Also I tried setting last working sim file as initial cache, failed too.
What is the proper way, fool proof method of doing this?
This is what I did
1. explicit cache last 5 frame named explicitcache.$SF.sim. Say, I got 100-105
2. delete last sim file (105).
3. reopen houdini. open scene
4. Reset Simulation on AutoDopNetwork
5. left start frame as 1 on AutoDopNetwork
6. set dop import rop to 100, hit render
    or set dop import rop tp 105, hit render
    or set cop import top to 106, hit render
all failed. It cook for a while on frame 106 then swoosh to last frame in few second. The bgeo file came out 500kb instead of 3GB, as it should.
I've been using H for a year and never get this thing right :(
Edited by poppy
