OpenVDB Hello World
I'm trying to figure out how to create an OpenVDB volume by writing out the voxels, to make a custom SOP.
The OpenVDB Hello World example goes something like this:
// Initialize the OpenVDB library. This must be called at least
// once per program and may safely be called multiple times.
openvdb::initialize();
// Create an empty floating-point grid with background value 0.
openvdb::FloatGrid::Ptr grid = openvdb::FloatGrid::create();
// Get an accessor for coordinate-based access to voxels.
openvdb::FloatGrid::Accessor accessor = grid->getAccessor();
// Define a coordinate with signed indices.
openvdb::Coord xyz(5, 5, 5);
// Set the voxel value at (5, 5, 5) to 1.
accessor.setValue(xyz, 1.0);
But now how would I get this to work in Houdini in my "cookMySop()" function? How do I attach this grid to a GU_PrimVDB (or something) to actually create the OpenVDB primitive in Houdini? Could I get a Houdini-specific "Hello World" example?
Edited by Kalina
Thanks, but that didn't get me very far. I now have:
openvdb::GridBase::Ptr grid = openvdb::FloatGrid::create();
GEO_PrimVDB* vdb = GU_PrimVDB::buildFromGrid((GU_Detail&)gdp, grid, NULL, "gridName");
which segfaults and crashes:
AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so>
AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo*, void*) <libHoudiniUT.so>
[0xf70e] <libpthread.so.0>
GA_PrimitiveFactory::lookupDefinition(GA_PrimitiveTypeId const&) const <libHoudiniGEO.so>
GA_PrimitiveFactory::create(GA_PrimitiveTypeId const&, GA_Detail&, long) const <libHoudiniGEO.so>
GEO_Detail::insertPrimitive(GA_PrimitiveTypeId const&, GEO_Primitive const*) <libHoudiniGEO.so>
GU_PrimVDB::build(GU_Detail*, bool) <libHoudiniGEO.so>
GU_PrimVDB::buildFromGridAdapter(GU_Detail&, void*, GEO_PrimVDB const*, char const*) <libHoudiniGEO.so>
Edited by Kalina
Thank you, I got it working!
openvdb::Coord xyz(5,5,5);
xyz.reset(0,0,0);
GU_PrimVDB* vdb = GU_PrimVDB::buildFromGrid((GU_Detail&)*gdp, grid, NULL, "gridName");
  • 2 years later...
I just updated to Houdini16, and all of a sudden this same little code snippet doesn't work anymore. Houdini crashes on the line:
...with no log or helpful error message, just:
undefined symbol: _ZN7openvdb11v3_3_0_sesi4math9TransformC1ERKSt10shared_ptrINS1_7MapBaseEE
Deciphering that with c++filt shows that it's complaining about:
openvdb::v3_3_0_sesi::math::Transform::Transform(std::shared_ptr<openvdb::v3_3_0_sesi::math::MapBase> const&)
...even though I'm not even using a transform. Any thoughts?
Edited by Kalina
Here is the full problematic code:
SOP_Testing.C:
#include "SOP_Testing.h"
#include <UT/UT_DSOVersion.h>
#include <OP/OP_OperatorTable.h>
#include <OP/OP_AutoLockInputs.h>
using namespace AVL_Testing;
PRM_Template SOP_Testing::myTemplateList[] = { PRM_Template() };
void newSopOperator(OP_OperatorTable *table)
    OP_Operator *op;
    op = new OP_Operator("avl_testing", "Testing", SOP_Testing::myConstructor, SOP_Testing::myTemplateList, 0, 0, NULL, OP_FLAG_GENERATOR );
    table->addOperator(op);
OP_Node* SOP_Testing::myConstructor(OP_Network *net, const char *name, OP_Operator *op)
    return new SOP_Testing(net, name, op);
SOP_Testing::SOP_Testing(OP_Network *net, const char *name, OP_Operator *op): SOP_Node(net, name, op){}
SOP_Testing::~SOP_Testing() {}
OP_ERROR SOP_Testing::cookMySop(OP_Context &context)
    xyz.reset(0,0,0);
    GU_PrimVDB::buildFromGrid((GU_Detail&)*gdp, grid, NULL, "gridName");  // Crashes on this line!
        // Complains about openvdb::v3_3_0_sesi::math::Transform::Transform(std::shared_ptr<openvdb::v3_3_0_sesi::math::MapBase> const&)
    return error();
SOP_Testing.h:
#ifndef __SOP_Testing_h__
#define __SOP_Testing_h__
#include <GU/GU_PrimVDB.h>
#include <SOP/SOP_Node.h>
namespace AVL_Testing {
class SOP_Testing : public SOP_Node
    public:
        static OP_Node *myConstructor(OP_Network*, const char *, OP_Operator *);
        static PRM_Template myTemplateList[];
    protected:
        SOP_Testing(OP_Network *net, const char *name, OP_Operator *op);
        virtual ~SOP_Testing();
        virtual OP_ERROR cookMySop(OP_Context &context);
#endif
Makefile:
CXX=/share/apps/bin/gcc
HOU_VERSION = 16.0
DSONAME = SOP_Testing.so
LOCATION = ~/houdini${HOU_VERSION}/dso/
SOURCES = SOP_Testing.C
include $(HFS)/toolkit/makefiles/Makefile.gnu
OPTIMIZER = -g
HOUDINI_DSO_ERROR = 2
CPPFLAGS += -fPIC
install:
    mkdir -p ${LOCATION}
    cp ${DSONAME} ${LOCATION}
Edited by Kalina
You need to compile with -DOPENVDB_3_ABI_COMPATIBLE (ie. define OPENVDB_3_ABI_COMPATIBLE) when you build your HDK plugin. This was accidentally left out of hcustom in early builds and looks like it's missing in the shipped Makefiles still.
Thanks, but that didn't help. The issue is still the same.
A bit more info that may be relevant, though: I am on CentOS 6, which comes pre-packaged with gcc4.4. You may notice that my Makefile points to
...where I have gcc4.9.3, which I'm trying to use instead. Am I using the wrong gcc version, or pointing to it incorrectly?
I'm pretty sure that this link error:
is caused by not compiling everything with -DOPENVDB_3_ABI_COMPATIBLE. One of the differences when this is defined is whether OpenVDB uses std::shared_ptr or boost::shared_ptr.
