kni8_2k Posted November 7, 2014 Share Posted November 7, 2014 (edited) Hi there I'm using the pop axis force but would like to use the VEXpresions to set radius and other parameters. but I can't access the shape parameters like radius and height. I think because these parameters are the actual shape parameters and not the per particle parameters that can be changed, but I'm not sure. Just that the ui is quite confusuing due to the location of the vexpressions dialogue. thanks for you help in advance. Ali popaxisforce.hip Edited November 7, 2014 by kni8_2k Quote Link to comment Share on other sites More sharing options...
ryew Posted November 7, 2014 Share Posted November 7, 2014 try using radius instead of @r - if you look at the pass through template, they use the full parameter name instead of r as reflected in the tooltip (looks like a typo by SideFX) Quote Link to comment Share on other sites More sharing options...
kni8_2k Posted November 8, 2014 Author Share Posted November 8, 2014 Thanks Ryew, but using radius does not update the shape node of the guide geometry. Which I guess is a different bug. Quote Link to comment Share on other sites More sharing options...
