edgem Posted November 13, 2014 Share Posted November 13, 2014 Hi everyone, Sorry for the nnob question...I am wondering if anyone knows how to set initial velocity in pyro SIM in Houdini 13 ? In previous versions, when we hit the billowy smoke shelves button, we had an applysource node which enable us to set it. Now it's not there anymore. Do we have to manually set the velocity into the object now ? Thanks Quote Link to comment Share on other sites More sharing options...
pbarua Posted November 13, 2014 Share Posted November 13, 2014 Velocity gets calculated at sop level using "Fluid Source" sop. Quote Link to comment Share on other sites More sharing options...
edgem Posted November 13, 2014 Author Share Posted November 13, 2014 Thanks Pradeep, I have checked the fluid Source SOP but I can't find where I can define the initial axis. For example if I want the smoke to push towards X axis, where do I define that ? Thanks Quote Link to comment Share on other sites More sharing options...
pbarua Posted November 13, 2014 Share Posted November 13, 2014 There is a toggle under Velocity Volumes called Add Velocity. Quote Link to comment Share on other sites More sharing options...
pbarua Posted November 13, 2014 Share Posted November 13, 2014 You can also use Fluid Source sop for pump source and velocity source by changing Initialize under Container Settings. Then read it in dops using source fluid dop. Quote Link to comment Share on other sites More sharing options...
pbarua Posted November 13, 2014 Share Posted November 13, 2014 "Pump From Objects" shelf tool does this automatically for you. Quote Link to comment Share on other sites More sharing options...
edgem Posted November 13, 2014 Author Share Posted November 13, 2014 Fantastic, Thanks Pradeep, working now Quote Link to comment Share on other sites More sharing options...
