pelos Posted November 15, 2014 Share Posted November 15, 2014 I have a vopsop node and I added a ramp parameter and a couple other toggle parameters, since this ones are automaticly promoted by Houdini, they do have lines to disable, hide, and a callback script, but doesn't let me change the option to python. so I manually edit the interface, I added a toggle and a ramp parameter directly to the UI. this params have more options than the one that Houdini promoted. and I am using this ones as temp parms. the temp parms have a script to modify the normal parameter and the other things I wanted to do from the beginning. example: ramp1 ramp manually done call back script, copy paste this ramp into the ramp 2 + print "hello" ramp 2 ramp promoted by Houdini this one is hidden and use in the vop sop. is there a way to be ale to tell the promoted parameters from Houdini to use proper callbacks? Quote Link to comment Share on other sites More sharing options...
