meshsmooth Posted August 18, 2004 Share Posted August 18, 2004 Is there some trick to copying text in some Houdini text panels, like the expression editor, the VEX Code tab of the Operator Type Properties and others. i have difficulty doing this in windows and Linux is this a long standing bug? Quote Link to comment Share on other sites More sharing options...
Stremik Posted August 19, 2004 Share Posted August 19, 2004 I'm not aware of anything like "Expression Editor" in Houdini! Do you mean Textport? If yes, than LMB to select a text in Textport and MMB to paste. Vladimir Quote Link to comment Share on other sites More sharing options...
Stremik Posted August 19, 2004 Share Posted August 19, 2004 My bad! There IS an Expression Editor. But what I said about Textport holds true. Vladimir Quote Link to comment Share on other sites More sharing options...
meshsmooth Posted August 19, 2004 Author Share Posted August 19, 2004 that thing that pops up if you hit ALT + e in any parameter or the text fields in the Operator Type Properties > VEX Code tab Quote Link to comment Share on other sites More sharing options...
Stremik Posted August 19, 2004 Share Posted August 19, 2004 He he. I beat you to it. (just read replys to your post at SideFX forum) In any case. I played with this "Expression Editor" a little and found out that just selecting text with LMB copies it and than Ctrl+V or Alt+V pastes it Vladimir Quote Link to comment Share on other sites More sharing options...
