How to run the code generated by hou.Node.asCode()?
magneto
I wrote the outputs of this function into a text file but I don't know how to run this Python code in Houdini. File > Run Script only support .cmd files.
I pasted the contents into the Python shell but it only created the container, and then errored out saying it couldn't find the parm.
Thanks.
exec()
import hou
out = hou.selectedNodes()[0]    #select first selected node
strCode = out.asCode(True,True) #get code, skip defaults, recursively
out.setName("newName",1)        #rename old node
exec(strCode)                   #run saved code
out.moveToGoodPosition()        #move old node so it's not overlapping
