g17 Posted December 5, 2014 Share Posted December 5, 2014 (edited) Hi , I am trying to do a clustered smoke sim emitted from a particle cache.basically i am following the the animated source points example file.I did the basic setup . The problem arises when i am trying to create the instance points for the containers.i need to create the instance points only on creation frame which is not working.i did a frame offset on the particle cache . but still i am unable to create the instance points . Since i am new to clustering i am unable spot the mistake or dont know whether i am doing the right thing .Can someone please have a look at the attached file and help me with this issue Thank you. Regards, Ganesh test_cluster.rar Edited December 5, 2014 by g17 Quote Link to comment Share on other sites More sharing options...
