sprite sheet tileable texture in comp
Hello,
I was wondering if there is a way to use the comp view to make a tileable flipbook?
I have created an animation, rendered it out, loaded it into the comp and used the transform to offset and wrap it to 0.5 U and 0.5 V.
I am getting the usual seam down and across the center, is there a way to clean this up?
Thanks
